Air bag shut off switch
Wood County Tx
Saturday whilst tearing the dash out, i noticed on my panel that holds the power point, that on the back of it, is the wiring and connector to turn off the passenger airbag.
so iffin get the switch will it work? or is somethinge else missing?
Fire1
Certified Diesel Driver
I think it takes a reprogram of the GEM module (at least on the older trucks). And from what I remember few if any would actually do it. You would first need to get the Federal paperwork to allow you to retrofit a cut-off switch since you have rear seats. Too many hoops for me. I'd like the option, but oh well.
Wood County Tx
i can swing the fed paper easy and be legal
just was curious about the switch working if i got one say from powerstroke shop
Fire1
There was a whole thread on this a year or two (or more) ago over at TDS. I think one person actually found someone intelligent enough at a dealership to do the reprogramming. Seems like the offiicial work around is an aftermarket switch add on. I seem to recall that Techs were either unable or unwilling to do the programming stuff.:dunno
Ford_Forgotton
To be legal, you need:
NTSB paperwork allowing the switch.
The switch
Reprogramming of your PCM.
Options!
Get switch from wrecked truck.
Get PCM from same wrecked truck. It will already be programmed for the Airbag switch!
Get a Jody Tipton chip to reprogram your power/shift points if the new PCM is different from your old PCM.
What happens if you install the switch without the programming, is the computer detects a FAULT and disables the ENTIRE airbag system.
Wood County Tx
thanks
I am filling out the fed papers hopefully today .
My dealer here is very open to this as long as said fed paper is correect.
preciate teh help ,
