AIC Issues
rsjohnsn
East Tennessee
Hi all, I have installed my AIC from my 2001 F250 7.3 into my 2004 F350 6.0 and I am having some issues. Everything works fine as far as operation but the idle is eratic. I can set the idle for 1200 and it will fluctuate all the way down to below 1100 and as high as 1300. What causes this? When the engine idles without the box it stays around 640 with a fluctuation of no more than 5 rpm either way.
Thanks
Scott
Butch Cassidy
Chelmsford, Mass
Rsjohnsn,
I also have experienced this erratic idle @1200 RPM also. The EBPV, due to cycling (IE: opening and closing) when cold could be the cause of this.
I am planning to disconnect my EBPV this coming Sunday to see if this cures the erratic cycling issue.
I will post my results.
Butch Cassidy
Northeast Texas
I know i read there were some issues using a 7.3 aic in a 6.0
but its on that other place i am forbidden to visit
Butch Cassidy
Chelmsford, Mass
Update on EBPV Disconnect
The surging I have experience using my AIC, is now gone. RPMs stay at 1200.:sweet
Butch Cassidy
FWIW,
The 6.0 also is equipped with the EBPV.
