Help Needed ABS light reset
steelhorse74
hamilton/ohio
Is there a way to reset the ABS light on a 2001 F250 without a programer. Just replaced bad ABS sensor in the front and the light is still on.
steelhorse74
hamilton/ohio
I disconnected the batteries for about an hour still had the problem. I think I will check the other two sensors to make sure they are clean.
NJKen
Is a proud new daddy
central NJ
ABS light will clear as soon as the problem is fixed. If its still on there is still a problem. Best thing you can do is get the codes.
Ken
trickyricky23r
