ABS for Fronts
scrawny
WVO PSD
Spokane, WA
Has anyone converted the front brakes on these trucks to also have ABS like the backs do?
patrickc
Ontario, Canada
I had an mid 90's F150 with rear abs and I disconnected it. I found that the rear abs sucked when it came to slippery road conditions. (front brakes would lock-up but the rear abs would kick in so the rear did nothing) I don't know what ford was thinking when they put abs on the rear and not on the front as well.
The only thing I have heard of is people disconnecting the rear abs rather than trying to put abs on the front.
caryt
Wellington Nv.
We don't have ABS, its a rabs valve and all it does is dump the pressure when it "thinks" that the rears are going to lock. A total piece of...just when you need to stop the truck will leap forward. Only cure to stop better is rear disks.
Cary
scrawny
WVO PSD
Spokane, WA
Front ABS
Isn't that what an ABS system is. A valve and a sensor that releases pressure when the wheel begins to skid?
patrickc
Ontario, Canada
Basicly but ABS is electronicly controlled each wheel has a ABS or speed sensor to help the computer determine what the wheel is doing from there it distributes brake pressure accordingly.
ranaumo
Diesel Junkie
LA - Lower Alabama, part of FL
Rabs Crap
OK, I agree with the rabs unit being useless in an emergency stop (even on dry pavement it kicks in). Is there a way to disconnect it, or maybe put a reducer in line to the rear brakes to not affect the front braking when it kicks in?
What options do we have?
Also have not seen a decent rear risk conversion for our trucks yet. Any new stuff out there I might have missed?
patrickc
Ontario, Canada
You can try disconnecting the sensor on the center of the rear end but it might throw the anti-lock/abs light on or unplug the wiring for the anti-lock/abs unit itself. I disconnected the unit on my 92F150 and it worked fine.
