ABS Controller Location
Kingdomflight
Lake Forest, CA
Does anyone know where the ABS controller is on an 02 F250 Super Duty?
I need to find the speedometer sensor wire that goes to this.
It's up in/under the center dash area. The actuator is on the driver side frame rail, near the fuel pump.
Proly second guessing you, but IF yer having Speedo/ABS issues (?) R&R the VSS (Vehicle Speed Sensor) first. It's located on the top of the rear Differential. $25.00 part, 20 minute fix.
Did they actually move the controller down to the frame rail I know that's where the actuator is but on the older trucks and most fords where I've had to replace them it was buried up in the dash near the center of the vehicle.
My BAD. I was thinking of the actuator, as it would relate to his Speedo sensor issues.
That's what I get for Second Guessing (assuming) ..... Sorry
Kingdomflight
Lake Forest, CA
ABS Controller
I have larger tires so I want to re-calibrate the speedometer with a Superlift TrueSpeed Unit. They say I must tap into the speedometer wires going into the ABS controller and I wanted to know where to find the controller.
I just looked and can't find anything by the fuel pump on the frame rail. What does it look like?
The ABS unit maybe on the hydraulic unit itself. It is in the '04s. Look under the hood at the brake reservoir and that area.
