A Couple Situations. Looking for Advice
dboyw
Lancaster, PA
Today while taking the camper to the campground I noted that the trans temp was 190 to 200. I do know that it usually runs 100* over ambient, which was 75-80, and it will run hotter towing, especially back roads. What I am wondering about is I can see the temp at say 190 but when I look at it the next second, or so, it will drop 10* instantly. Trans fluid is full, I checked the connection at the sender, and it seems OK. What else?
Then on the way back home, the truck just felt different. I noted twice that the check engine light came on for a few seconds, but then would go back off. Once the go pedal had no response, but then reacted again.
Suggestion, ideas, comments?
Thanks
you need to pull codes
but I'm bettin you're the proud owner of a screwy ground connection
