SMOKNZ
Earlier in December I took my truck to tow my snowmobile trailer a couple miles away to a friends field to play around. On my way I noticed the truck loosing power and I could barely do 50 mph with it floored. I limped it to my destination and it then died. I attempted to start it and it would attempt to start but would not catch. I had this issue last winter when I had water in my tank, so I dumped the fuel filter bowl and refilled the filter housing and tried again. I replaced the fuel filter and tried again, no luck. I towed it home and it has been sitting in the yard ever since. I had run Biodiesel in it all summer, and I had just about run it out and then filled with normal diesel. I figured maybe the bio gelled or something and I would have to wait until spring when it thawed out. I have tried on 2 seperate days now when the temps have been above 40 to start it. Today was above 50 and still it wouldn't start. I even pulled the fuel filter and drained the filter bowl and turned on the key to verify that the fuel was liquid, which it was and it seemed to pump into the filter bowl OK. I'm thinking I have another issue. Due the the fact that it seemed to fade away over a few miles and then die I wouldn't think it was the CPS. It tried to start and will even chug a few times and die. Dark smoke comes out the tail pipe during this time, so it seems the injectors are firing. I cannot verify fuel pressure yet as my gauge is not hooked up. WHat else can I check? I know my batteries aren't the greatest. After fully charging they won't crank but a few minutes and they are pretty drained. Start here? Any help would be appreciated
Bill
Bill
