99 7.3 in a 95
happeetxn
9/11 Never Forget
Dallas
Would it be a PITA to put a 99 7.3L in a 1995 F-350. I would be using the transmission from the 99 if that makes a difference.
Craig
Its the same block so it should bolt right in however..... The 99 was intercooled, had a different turbo and will need the PCM from the 99 also.
happeetxn
9/11 Never Forget
Dallas
I'll have to check and see if all of that stuff comes with the motor or is extra $$$ Thanks,
Craig
Allan B
Northern Ont,Canada
I put a 2000 e450 van motor in my 95f350 4x4 . no problems,changed the oil cooler,valve cover gaskets,& installed the electric fuel pump.The van turbo doesn,t have a wastegate.I tried to fit a wastegated turbo, but it was hitting the firewall.
happeetxn
9/11 Never Forget
Dallas
Thanks for the info. If I decide to get the engine and do it I will probably bother you for more info and details.
Thanks,
Craig
