99.5 powerstroke upper end knocking
cruiserhed
Hi all,
I've got a knock, or loud tick coming from I think the top of the engine. I increases and decreases with rpms. Sounds just like a collapsed lifter but I've got the valve covers off, have rolled the motor over manually, the valvetrain seems tight. No loss of power, not even a miss. I popped each injector harness off one at a time while it was running and noticed a drop in rpm each time, so Im assuming they're working. glow plugs are all there and in good shape, I read that one could've broken off into the cylinder but that's not the case.
any suggestions? could an injector be bad or causing a knock and still be functioning?
Im in the garage right now so any ideas are appreciated.
thanks
99.5 7.3L, 160k miles, oil changed regularly, no other symptoms.
cruiserhed
nothing yet!
No good progress yet, tank is about 2/3 full. I haven't let it get down below about 1/4 of a tank in a while either.
thanks for the replies.
I'll keep trying.
dzl_x_4x4
Dzl_X_4x4
Rowlett, Texas
Did you or anyone work on your truck lately. Is it a tick or a KNOCK? Did it happen after a fill-up,? while driving? or just happened over night?
cruiserhed
latest
It started the other day on the way home, seemed to start like a very light ticking and progressed to more of a knock. It got to a point and peaked and it is the same now all the time. It was between fill ups, nothing had been done to it recently. I put some power service in it since then and drove it to and from work just to maybe get lucky but it hasn't gone away. I just bought a few good used injectors and my next plan is to switch them out one a time and see what happens, it's parked now, I don't want to keep driving it like this.
keep em coming and I'll keep you posted how the injectors work.
dzl_x_4x4
Dzl_X_4x4
Rowlett, Texas
Does it smoke (white,blue,etc.) on startup or running?
FWIW: I would look for fuel leak or an oil leak, I am certain that both could cause these symptoms. If you get air into either system you can get a heavy knock. Mine sounded like someone was beating on it with a hammer before I did the oil high pressure cross-over mod. (mine is a 7.3). If you did that look to see if any connectors or oil plugs are leaking. If not, I would do it when was replacing the injectors (hour job, $50) it made mine very quite.
cruiserhed
hmm interesting
thanks, I might have to try that kit. I swapped out injectors today one at a time and not a thing changed, still knockin away.
I think I've isolated it to pass. side front, but that is as close as I can narrow the knocking. Definitely upper end.
I haven't noticed any unusual smoking at startup, but I'll take a closer look for leaks. Where did you buy crossover mod, I might have to try it.
thank you
