97 o ring question
TurboTy
Toms River, NJ
i was just wondering if the oring kit for the drain on the water seperator are the same for the early powerstrokes as they are for the 99 and up?....i just did mine on my 00 and they worked great, my friends got a 97 with the same fuel leak mine had, so i was wondering if they are the same or their is different part numbers, thanx for any info!!:thumbs
Ive got the PN# for the water drain valve on the OBS trucks, but IIRC the fuel filter bowl is a different animal between the OBS and SD's.
Fuel Filter Water Drain Valve (94-95)
(Ford) F5TZ-9A153-A
