8" with 38's?
orion_134
Woodbridge, VA
Looking to get a Superlift 8" and some 38's on 16" or bigger Centerline Wildcats, but I need to know what backspacing/width rim I need. I heard if the backspacing is wrong it could lead to accelerated hub wear...no good, I need this to be done right the first time.
Thanks in advance,
Jesse
nevrnf
NW IL
4.5" back space so it does not rub on the spring. Wheel bearing failure is going to happen no matter what combo you go with. 10 or 12" wide wheel with a tire that weight 100# is going to kill the factory bearing.The only way to avoid it is to do a Dynatrack kit on the front.
