7.3L Reliability
XXHeavyDutyXX
California
Hey guys,
I know there are alot of issues with the turbo on the 6.0 model and that's why
I'm staying clear of that engine. As far as 7.3, I haven't heard to much on reliability. If anyone has info on the pro's and con's of that engine, that would be much help. Anyways, I'm looking at a 2002 model 7.3 PSD.
Thanks for the help
:thanks
oi8228oi
another 99
welcome
both the 6.0 and 7.3 are great motors... (problems with 6.0 are minimal....) 7.3 do have turbo surges, which can be fixed with either a compressor wheel, or housing, or both... like any diesel its gonna take about 4 gallons of oil for an oil change.... if your gonna be towing or moding, the first thing you should do is throw some gauges on there, and i would put a deeper transpan on... there not known for having the toughest factory transes, but i havent had a problem...
I know ive given cons, but believe me there are far to many pros for me to list... i love my 99.5 7.3 and wouldnt trade it for anything....
good luck
The Cam Position Sensor (CPS) can go out on you at anytime. Many here carry a spare CPS in the glove box. I had an earlier model that was completely non computerized and non turbo'd and it was bullet proof.
Long as it doesn't have mega mileage on the odometer I wouldn't think about it for I might swoop in there and snatch it up:D ;)
Been driving 7.3L's since '96 and never had any issues outside of the rare CPS glitch :sweet
The 7.3L has the thumbs up from me:burnit
Big K
SDD.com Hacker/Admin
Dallas, Texas
225K Miles on mine.
It put me on the side a few times, but was because of the CPS or something else that I did! :rolleyes: (unrelated to the Engine)
ford4life
Commercial Farm Truck
North Carolina
231,000 on a 99 F-250 daily driver that frequently tows, 179,000 on a 99 F-550 rollback, 337,000 on an 88 F-350 IDI. I'm not worried about reliability, just how soon I can get some more mods put on.:thumbs
Djracer
Car Stereo Dude
Wetumpka, Alabama
I just got my 7.3 but I like it so far!
I don't know where everyones manners are Welcome to the board from Alabama!
Hoss 350
My GSP, Dutch
Spokane, WA
The 7.3 is an extremely reliable engine, with a list of true problem so short that I can list all of them right now. It is not unheard of the hear of these things going 400K without a glitch, but when you have a problem, you can bet it is one of the following:
ELECTRONICS
1.) The CPS (Camshaft position sensor) has a reputation for dying quite often, without warning. It leaves the truck totally inoperable. The good thing is that they are super easy to change, so you can carry one in your glovebox and fix it real quick if it goes. See Wiki for more info.
2.) Glow plug relay - This $40 relay tends to not last long under the high amp loads of the glow plugs. Some guys replace one a year. I've never replaced mine, but my truck does smoke on cold mornings, so it probably needs it soon. Best case, it goes out slow, gives you indication it is going out by smoking and hard starting in the morning. Worst case, it goes out fast, and you can't get your truck started one very cold morning.
3.) Fuel heater- Tends to burn out occasionally. MUCH more rare than the other two items, but the result is the same. YOur truck won't run until you fix the problem. THis happens on maybe one out of 50 trucks, and will only happen once in the truck's lifetime if you're the unlucky one.
MECHANICS
1.) The 7.3 IDI engine (more or less the same as the 7.3 PS mechanically) had SERIOUS problems with cavitation. The problem came from miniscule movements in the pressurized water jacket from stresses related to the high compression ratio of the old IDIs. The movements created sudden pressure drops, causing cavitation in the water jacket 1,500 times per minute, which slowly eroded the cylinder walls until you had holes in your cylinders, and a wrecked engine. This is almost UNHEARD of on the 7.3 PS, and is totally avoidable by simply adding a nitrile additive to your antifreeze at regular intervals. Just for your info, many, many diesel engines, from all manufacturers, have the same problem.
2.) Rods - The stock rods on a 2001 and newer truck will "only" hold about 375 to 400 horsepower before they go. Not a big deal if you are not planning on rodding your truck, but if you are, either plan on replacing rods, or get a 2000 or older
3.) Auto tranny - Like every single diesel truck ever released up until recently, the auto tranny was insuffcient at best behind the high torque of the 7.3. Upgrades are almost necessary, if not highly recommended.
4.) Water pump - they go out a lot. Casting sand from the factory comes loose in the water jacket occasionally, and eats up the bearings. Coolant filters solve this problem. Easier than heck to change out, not really a big deal
THE REST
Best darn truck I've ever owned. Period. Hands down, no questions asked.
XXHeavyDutyXX
California
Wow Hoss 350! Very informative. That's exactly the answers I was looking for.
If I do get a 7.3L, I'll print this page and put it in the glove box...just incase.
Looks like i'm closer to leaning on getting a 7.3L:D
_____________________________________________
2003 Toyota Tundra 2wd(has balls, but unloaded)
