I'm needing a little help here. The whole story....over the last few weeks I've noticed a small amount of diesel in the driveway and other places I've been parking. I looked under the hood (and several posts here) and it appeared my fuel bowl drain valve was to blame. I replaced it yesterday along with a new fuel filter. After I completed these two, I started it and let it run for 3-4 mins, check for leaks, and after everything seemed dry I called project complete. THEN...I jump in it this morning and to head to work and it started just fine. I noticed in the side mirror that the blue/white smoke didn't stop after a few seconds after starting. After 15-20 seconds I noticed it begin running very rough and eventually so hard it quit. Now it won't start at all.
After reading here I suspected air in the fuel lines. I have cycled the key several times (5-6 times) and opened the new drain valve (and fuel does flow out) but still won't start.
Any ideas??? Everything was running just fine before the new drain valve and filter yesterday.
