6 inch fabtech
Harley6.0
Harley6.0
Delafield, Wisconsin
I have an 06 F250 Harley Edition. I want to put a fabtech 6 inch lift on it. All the lift shops have been telling me i can't put 37's on it. I was wondering how much trimming people had to do to fit 37's on there trucks. I was planning on going with a 37-13.50-20 in a toyo open country mt.
patrickc
Ontario, Canada
I had 37's on my 02 F350 with a 6" skyjacker lift without any serious clearance issues. (super swamper irok's 37x13.5R16's) On mine I had to trim the lower front bumper valance (plastic) because the lugs on the outside of the tires hit it when turning other than that their was lots of clearance everywhere else.
irish4x4
Mayor of Margaritaville
Reno, Nevada
I run the 37x13.5x18 Toyos with a 6" lift. I get some tire contact on the right leaf pack at full right turn. Since I did the 2" lift shackles it pushes the axel foreward some. So I didnt rub on the fender skirt I rubbed on the front bumper and lower valance. Good excuse to get out the cut-off wheel! You can see in my pics (in the gallery) that I did'nt have to remove too much from that front bumper corner.
rynarnell
03 6.0 8.0lift on 38"s
alaska
you shouldnt have a problem, just a little 45' agle cut on the lower bumber valance. You shouldnt rub either during the turn cause of the coil springs.
NDsuperduty
Kingwood, TX
Sorry to bring up an old topic, but if I have the 6" fabtech and a ranchhand bumper replacement (like in my avator) should I be able to run 37's if I get aftermarket wheels?
Buffs F-350
New Jersey U.S.A
I just have a 2 1/2" spacer and stock rear springs and im running 35/13.00r18 on stock rims just trimed a little off the bottom of the plastic inner fender and no rubing. A 6" with the proper back spacing on the rims should have no problem with 37s.
georgetown texas
Buy you a set of rims with 4.5 inches of backspacing and you'll be good to go. Joe is runnin 37's on his with a 4 inch lift.
lvtitan
prototype
$in city
i had a 6" lift and had to trim the front valance to run 35's.. you will have clearance issues with 37's... sorry to bust your bubble, you can run them, but they will rub and will probably look like crap with only 6" of lift.
NattyGlee22
