It is a moderately easy task. It will bolt into the stock location of your current cooler. The hardest part is getting the old one out and the new one back in. I removed the front grill and the x cross bracing. It made it easy to get in. The next step will be to get some fittings to adapt the 3/8" hose to the 1/2" hose the 6.0 cooler accepts. If you need anymore info, just pm me.
Hope this helps,
J.J.
