6.0 IC and Tranny cooler in 7.3
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
I may have access to a wrecked '05 6.0 for parts :D :sly
Is the 6.0 IC an upgrade for a 7.3?
If so is it a hard install?
I know the 6.0 tranny cooler is an up grade, do you run the stock tranny cooler and the 6.0 cooler together, or just the 6.0?
How hard to put the 6.0 tranny cooler in the 7.3?
Thanks a bunch
Neal
dpantazis
#12
under the cheddar curtain
IC is upgrade. do it.
6.0 cooler replaces the 7.3 one. its like 3-4 times as large. it bolts right in. only change is transitioning from the 3/8" lines on the 7.3 to the 1/2" on the 6.0 one. hose routing is the only 'hard' part.
you might grab mirrors too, or at least grab me the connectors and maybe the parking lamps? ;) ;)
platinum01
Willis, TX
I have heard that the IC is an easy change out but have also heard that the V10 Tranny cooler is much better for cooling the tranny. If I am wrong please tell me but I believe that it was hear that I heard that.
