oops...edit... I have had my EX 18 months, 31K miles!!!
I have had my EX a year and a half and 31K miles now, and have been quite happy *AFTER* getting it lifted 4" and putting real tires and shocks on it. I off-road and tow seriously, all the time, and stock the truck is unsuitable for either.
The factory tires are just, well, silly...
http://www.martialartsacademy.org/levilift.htm
Then putting on the LandYot Radius Rods.
Then fixing the frame:
http://www.martialartsacademy.org/Leviweldfailure.htm
I just picked my truck up from the Ford dealer, VILLA FORD in Orange, California.
I was very pleased with them!
My issues in a year and a half that needed addressing:
1.
Recall from Ford to replace an exhaust sensor and reflash.
Result: better pick-up, much less turbo lag, slight increase in mileage.
2.
Loose wire on positive terminal of left-side battery.
Result: replaced nut, tight now.
3.
Boot on drag-link torn at steering box pitman arm.
Result: replaced entire end of arm and free alignment.
4.
Oil leaks at all (especially left-front) flexible connections of intercooler hose.
Result: tightened and cleaned.
5.
Left and right front windows scratched from dirt getting stuck in felt
Result: new windows ordered, to be installed.
6.
Switch to right rear back side-opening window in overhead console
failed, shorted and melted plastic console.
Result: new switch, console on order to be installed.
7.
Back-up alarm failed, sounds at all times.
Result: sensors to be replaced.
8.
Hydro-boost pump noisy.
Result: replaced at no charge, and what a difference! I did not know that there should be ZERO noise from this pump, it has made noise and even howled from the first month.
My brakes work better and my steering is now silent.
All this warranty work was done quickly and for absolutely NO CHARGE under the factory 36K/3year "bumper-to-bumper" warranty...as of course it should be...
1.
2.
3.
4.
5.
6.
7.
8.
