TampaDieselFX4
Had them put on yesterday. Kept my factory 20" wheels. the tires measure 33.5" tall on the truck... pretty much the same height as the OEM Goodyears; maybe a 1/2" difference or less. So far I like the tires a lot. Very quiet, deep treads, siping and E range. 40K warranty also
I actually kept the front mud flaps on, they don't even rub, it's close, but clear, couldn't believe it myself They also don't even come close the front bumper valance... miles away. Kinda sad, I don't need my 4" lift to run them even. Tires still look WAY to small for the truck on that lift. I'm guessing if I had 20x10 aftermarket wheels I'd need the lift. on the stock wheels, with no front mud flaps, and some trimming I bet I could EASILY clear 37's.
The shop set them to 55psi F&R. Today, I Used Whiteout and drove around the neighborhood and looked at the wear pattern. I dropped the rear down to 50psi and the pattern is much better, but not 100% perfect even wear. I didn't want to go under 50psi, but I'd like to try 50 in the front & 45 in the rear. I bet that would give it perfect wear. but does that PSI sound to low???
