PHXF250
Diesel Freak
I'm gonna do some front end work on my 1999 F250 SuperDuty. The upper and lower ball joints are loose in there sockets and the front suspension sag quite a bit (They have have the weight of that Diesel Engine on them for 10 years and 215,000 miles).
Anyway I went out to price out a DayStar leveling spacer kit for the 2WD and they dident recommend it and said I would probably have to spend 3 hours labor to get the Alignment right. The funny thing about this is the construction company I bought the truck from gave me there maintenence records and 50000 miles ago the alignment shop recommended new springs and installed the Largest offset cams in both side and Camber is Maxed out at 1/4 neg.
Long Story Short, I want to raise the front end up a bit to get the truck closer to level. I am not gonna install larger tires, (gonna install New set of Michelin XPS RIB 235/85/16 I just think the duped front look goofy. I realize new springs will also raise it up a bit but I like the Idea of Spacers on the old springs as the ride would probably be nicer the the super stiff new spring. What I would really like to do is install some leveling front springs like the T-Rex Ones I put on my old Dodge Ram 3500 4X4 I had. No Spacers just longer stock looking springs.
Thanks PHX F250
Thanks PHX F250
