2009 F-250 Lift/Tire???
TxHighroller
Centerville, GA
Hello,
I am new to the site and just purchased a new 09 F-250 Lariat w/ 18" wheels. The truck came with 275/70/18 tires and I would like to go w/ 35's. That said, my 02 F-250 needed a 2.5" leveling kit to run 35's. The 09 appears to be level. That said, what is needed to run 35's (leveling kit, lift, etc...). Also, my 09 F-250 came with the two tone paint and has a trim piece that surrounds the wheel wells (if this matters). Any input/suggestions is greatly appreciated.
Thanks,
Brandon
:welcome4 TxHighroller. You will probably need the same lift as with your other truck. It will be easier with the coil springs. The front bumper may need to be spaced out a bit to clear the turns.
trickyricky23r
