2002 f350 blowing oil from dip stick
Kniel3378
St.pete florida
So I had the oil changed and it still seems to be doing it. Again the CCv was checked and is working properly. Was at my local ford and the diesel mechanic said it could be a cracked dip stick tube.
He also cleared up the if there was too much crank case pressure it would have actually pushed the dipstick out which I didn't. So the leak could be from the dip stick tube itself. Still trying to find the leak.
Is the oil coming out of the Top of the dip stick tube ? If so, on the top of dip stick.. there's a plug type seal.. check that out. If it's shot.. you may just need a new dip stick.
Pm_guru
