Dec 17, 2007 #1 S Stroke Full Access Member Joined Nov 17, 2007 Messages 105 Reaction score 0 Location Salinas,California What is the bolt pattern onthe 08's? is it the same as the 04
Dec 18, 2007 #2 Buffs F-350 Full Access Member Joined Jan 18, 2007 Messages 361 Reaction score 0 Location New Jersey U.S.A I guess you meen the wheels all superdutys are 8x170mm bolt pattern the back spacing on the 05 and up is different than the 99-04.
Dec 25, 2007 #3 Y Yanqui SDD Junior Member Joined Feb 4, 2007 Messages 9 Reaction score 0 Location TX 08 Wheel Specs My 07 bolt circle is 8 / 200 mm with 5.55" off set. You can read up on the 2008 Wheel Specs here. Should be on page 33. yanqui
Dec 25, 2007 #4 95_stroker Jefe Joined Mar 28, 2005 Messages 6,809 Reaction score 3 Location Cora, Wy Yanqui said: My 07 bolt circle is 8 / 200 mm with 5.55" off set. Click to expand... DRW?
Dec 25, 2007 #5 Y Yanqui SDD Junior Member Joined Feb 4, 2007 Messages 9 Reaction score 0 Location TX Yes....DRW Ford Fleet has spec info going back to the 2000 MY. Last edited: Dec 25, 2007
