05, 06 Wheels on a 00
shannoncaldwell
Houston, TX
I have put 06 Lariat 17" wheels on my 00 Excursion. The wheel dish is different and the wheels and tires are set further in. The front tires even rub the antisway bar with stock tires.
Is there a fix for this, has anybody done this successfully? Or should I just go back to my original wheels?
Thanks,
Big K
SDD.com Hacker/Admin
Dallas, Texas
Backspacing isn't correct unless you use spacers.
I would get the correct wheels for your truck ;)
wphares
Dothan, AL
I used spacers on a 99 sd and it worked fine. My friend actually grinded down where it was hitting on his mothers 00 excursion.(wouldnt advise this but its an option)
