Houston................
Tbar
SDD STAFF/Moderator
...........We have a problem.
Rips me that I let this happen. I take care of my equipment better than this. Don't recall ever hearing the squellers until today when I heard the grinding.
Tbar
platinum01
Willis, TX
:eek: :eek: :eek:
WOW nice. How bad is the rotor? Wife truck just started squelling. Think I'll give them a look. Sorry to see that.
Weweld
Fillmore Ca.
My F450 did the same thing and chewed the rotor real bad didn't hear anything till the grinding :eek: :eek:
patrickc
Ontario, Canada
Last time I saw a set of pads like that I had a seized caliper. Mine did the same thing no warning until metal on metal. Not to many of the superduty pads have squellers on them.
Tbar
SDD STAFF/Moderator
I need a set of rotors like today...............what local purchases have ya'll made and how did they work out???
Tbar
Ok not like you need to hear this from anyone...its painful enough as it
is...
Its one of the things i do & its probably the largest reason i have for
rotating tires...every time i rotate the tires i duck my head in (and if
necessary shine a flash light) on the brake pads...and i check EACH
pad ('case im getting uneven wear).
OE replacement rotors are reported as 59.99 each from autozone.com
cyro-sloted rotors are gonna be about 150 each.
LIFETIME warrenty OE replacement pads from autozone.com
are 23-54 bucks per pair.
New (COMPLETE/LOADED) brake calipers ('case you have a stuck
piston & dont wanna rebuild 'em yourself) are 154 bucks per PAIR
(again autozone.com)
Tbar
SDD STAFF/Moderator
Autozone - $94.00 Duralast(house brand)
O'Reilly - $49.99 Brakelast(house brand)
Tbar
thats pretty close.
i gave 138.00 each for the fronts,
and 127.00 each for the rears.
the cryo precess was about 40.00 for each rotar (included in price above)
well worth it for me with the heavy towing i do (maybe not be necessary in for others tho)
you can look at them today,and they hardly show any wear, a very good product. JMHO
