PART NUMBERS PAGE
JOAT
I Found Nemo!
The West Coast
Hey guys,
Alot of you probably already know about the PARTS PAGE I maintain (link is always in my sig), which is primarily geared towards 94-97 PSD's, but I'll list other Ford diesel parts if offered. If I get enough of any specific generation I'll start separate lists.
Anyway, feel free to send me part numbers as you get them. Often Ford changes numbers so I am constantly changing obsoleted ones as I get them. If you don't know the range of years a part number works for, at least tell me what year you bought the part for so we have something to go by.:thanks
Thanks:sweet
JOAT
I Found Nemo!
The West Coast
Awesome!
I'll get on it after dinner:thanks
Which parts were included in the shift assembly?
Radarman
Beaverton, OR
Just got off the phone with fella at fordparts.com. Sounded very informed.. Anyway.. here is what I got; several numbers are different than what you had listed:
2002 HPOP GASKET F6TZ-9417-AA
1995 1C3Z-6K649-BA OIL COOLER O RING (4 REQUIRED)
1995 F4TZ-6A636-A OIL COOLER GASKET
1995 F7TZ-6A636-AAA OIL COOLER GASKET
1995 F4TZ-9D930-K UNDER VALVE COVER WIRE ASSEMBLY
1995 E7TZ-7515-A LEVER ASSEMBLY - CLUTCH RELEASE FORK
Thanks for everything, keep up the great site!
Chris
tubzz
st.clair mo.
here another one for ya
the exhaust manafold to block bolt F4TZ-9S425-A
they are a flanged head bolt with a specail prevailing torque thread
94f450sd
certified nutjob
plymouth,ma
heres another number for you.
YC3Z-6020-BA -it is a timing cover seal kit that comes with all 3 of the different HPO reservoir gaskets,timing cover gaskets,water pump gasket,oil pickup tube gaskets,tube of RTV,3 hole HPOP gasket
Brad1103
