Cleaned intercooler piping boots, found lots of oil?
orion_134
Woodbridge, VA
My boots were leaking so I took them off to clean them and found a moderate amount of standing oil in the boots. I say moderate, but I really have no idea what is normal for the trucks. The reason I post this is because I wanted to do the mod that eliminates the PCV going into the intake tube, but I am not too happy with rerouting the PCV to the back of the engine bay, on the header, etc. I don't want the underside of my truck coated in oil.
So two questions, would a catch can work in this scenario much like in a gas motor?
And is ok to see a little bit of standing oil in the ic boots?
Jesse
roosterdiesel
Earl needs B100
Amarillo,TX
Some people have had problems with catch cans causing positive crankcase pressure. Not good! Gone back to atmosphere venting and problems go away. You can always run it to the back of the vehicle, mine drops down just above the rear-end housing.
Here's what my hoses looked like.
vbpicgallery.php
oi8228oi
another 99
would you rather that stuff in your intercooler, muffler or underbody of your truck...
personally im fine with it on the underbody... i painted and undercoated everything underneath there about 2 months ago so im content with it for now...
dpantazis
#12
under the cheddar curtain
for the record- doing the ccv to exhaust mod is effectively making it exhaust to the free air and is against the polution control regulations.
you could instead, install a proper CCV filter from MANN, Donaldson, etc. which are DESIGNED to filter out the oil. they have proper breathers and pressure valves. they are about $150 or so.
http://www.mann-hummel.com/industri...eys=22.1.252.1.1&cScr=75&v_pbid=19&v_pid01=44
http://www.donaldson.com/en/exhaust/emission/index.html
the donaldson has CARB certs too.
dennis
orion_134
Woodbridge, VA
I am beginning to like the idea of running it under the truck, unless someone can tell me if there is any threat of the exhaust backflowing into the intake. I installed something similar to this on my racecar and had to have a check valve.
Jesse
whatabudro
Launched
The CCV should not be put into the exhaust before the muffler with a stock exhaust. MY OPINION- Bryan
gotogelsuper8461
